95 gsr into 93 civic si hatchback wiring questions
Hi, I've done a lot of research and it seems like there is a lot of misinformation!!
First off, I have gotten the D series motor out. I would like to use the GSR motor harness to plug into my stock 93 Civic SI firewall harness.
According to http://www.ff-squad.com/tech/w...5.jpg, I need to wire up the IAB and the evap purge solenoid.
However, according to C-speed's how-to (http://www.c-speedracing.com/h...4.php), only the IAB and the knock sensor needs to be wired up. It mentions something about A20, which I don't understand.
Any insight guys? Did I mention I hate wiring??
Mr. Badwrench
Re: 95 gsr into 93 civic si hatchback wiring questions (nightrider)
the last one i did with a complete harness all i had to do was knock and iab.
quick search for pinouts:
OBD1
A1-INJ1 INJ1
A2-INJ4 INJ4
A3-INJ2 INJ2
A4-VTS VTEC solenoid
A5-INJ3 INJ3
A6-PO2SHTC O2 sensor (heating element)
A7-FLR1 fuel pump
A8-empty
A9-IACV IAC valve
A10-empty
A11-empty
A12-FANC engine coolant temp switch
A13-MIL MIL (check engine light)
A14-empty
A15-ACC (a/c compressor clutch)
A16-ALT C alternator
A17-IAB IAB Solenoid
A18-empty
A19-**
A20-PCS EVAP purge control solenoid
A21-ICM ICM
A22- *per Sander* Ignitor
A23-PG1 ground
A24-PG2 ground
A25-IGP2 to main relay and to gound for o
A26-LG1 gound
B1-IGP2 to pin A25
B2-LG2 ground to shields for CYP & TDC
B3-**
B4-**
B5-ACS a/c switch
B6-empty
B7-**
B8-PSPSW PSP switch
B9-STARTER SIGNAL starter signal
B10-VSS vehicle speed sensor
B11-CYP P CYP -P
B12-CYP M CYP -M
B13-TDC P TDC -P
B14-TDC M TDC -M
B15-CKP P CKP -P
B16-CKP M CKP -M
D1-VBU Back Up Power
D2-BKSW brake switch
D3-KS Knock Sensor
D4-SCS service check connector
D5-empty
D6-VTM VTEC pressure switch
D7-TXD/RXD (data link connector)
D8-empty
D9-ALT F alternator
D10-ELD electric load detector
D11-TPS TPS Signal
D12-**
D13-ECT ECT sensor
D14-PHO2S O2 sensor
D15-IAT IAT sensor
D16-VREF VREF
D17-MAP Map Signal
D18-**
C19-VCC1 MAP 5V
C20-VCC2 TPS 5V
C21-SG1 MAP GND
C22-SG2 TPS GND
OBD1
A1-INJ1 INJ1
A2-INJ4 INJ4
A3-INJ2 INJ2
A5-INJ3 INJ3
A7-FLR1 fuel pump
A8-empty
A9-IACV IAC valve
A10-empty
A11-empty
A14-empty
A18-empty
A19-**
A21-ICM ICM
A23-PG1 ground
A24-PG2 ground
A26-LG1 gound
B1-IGP2 to pin A25
B3-**
B4-**
B5-ACS a/c switch
B6-empty
B7-**
B8-PSPSW PSP switch
B11-CYP P CYP -P
B12-CYP M CYP -M
B13-TDC P TDC -P
B14-TDC M TDC -M
B15-CKP P CKP -P
B16-CKP M CKP -M
D3-KS Knock Sensor
D5-empty
D8-empty
D9-ALT F alternator
D11-TPS TPS Signal
D12-**
D13-ECT ECT sensor
D14-PHO2S O2 sensor
D15-IAT IAT sensor
D16-VREF VREF
D17-MAP Map Signal
D18-**
C19-VCC1 MAP 5V
C20-VCC2 TPS 5V
C21-SG1 MAP GND
C22-SG2 TPS GND
Re: 95 gsr into 93 civic si hatchback wiring questions (boostedcivicsir)
so the gsr doesn't have an evap purge solenoid or it's already wired up and good to go?
Mr. Badwrench
i wasnt aware they were different, the one i swapped was fine, 92 or 3 cx ( been so long ago i cant remember ) 94 gsr, swapped the whole harness, took the knock and IAB from the gsr harness at the strut tower and ran them to the ecu.
it has to have an evap purge valve.
Zerob16eg
05-05-2008 10:50 PM
TheMostSadistic
04-24-2003 11:15 AM
