Mount Question: read something I want verified
I'm putting a B16 from a Del Sol into my 6th gen coupe.
on Http://www.hybrid.honda-perf.org
he states that on the lower front mounts you should use the civic rubber, and stud.
is this REALLY necissarry? I'm ok w/ using the civic rubber....but the Studs have GOT to be the same....I don't want to change out the studs.
Re: Mount Question: read something I want verified (DragIIcivic)
c'mon....I know someone did this swap themselves...Which hardware did you use??
1 Post
you don't need to change the studs. Only if you strip them or something.
*edit* ..you're talking about the drivers side? or the passenger side?
[Modified by fowler, 9:27 PM 11/21/2001]
Re: Mount Question: read something I want verified (fowler)
Both should be the same, no?
jonstaub2011
11-30-2010 07:14 PM
black'n'white
01-12-2008 10:34 AM
