5 Lug Conversion Comparo: CTR Vs. ITR... What are the differences?
Old Nov 27, 2001 | 12:08 AM
ESCALVANTE's Avatar
Default 5 Lug Conversion Comparo: CTR Vs. ITR... What are the differences?
What are the differences, if any, between the CTR and ITR 5 Lug Conversions other than in name?
Different Brake Disc Sizes?
Different Sway Bar Sizes?
Different Control Arm Designs, etc., etc.?
Old Nov 27, 2001 | 02:53 AM
rainforest's Avatar
Default Re: 5 Lug Conversion Comparo: CTR Vs. ITR... What are the differences? (ESCALVANTE)
i don't think its anything but the name.
Old Nov 27, 2001 | 06:42 AM
fowler!'s Avatar
depending on what car you put it on...it makes a difference. If the swap is going on an EK, you want to get the CTR 5-lug. You can't use the DC lower control arms...so you have to use the stock ones. CTR is able to utilize the entire assembly.
If its going on Eg, I'd say get the ITR conversion. Everything bolts up fine.
I think that the ITR brakes are a little bigger...but don't quote me.
Old Nov 27, 2001 | 07:20 AM
jeff652's Avatar
the knuckles and trailing arms are identical. There are differences in the control arms, but those do *not* have to be changed when doing a 5 lug conversion. There is no difference in brake size, in the front or the rear . .
HTH
Jeff
Uneekpinoysk8er
Dec 25, 2004 08:27 PM
Uneekpinoysk8er
Nov 21, 2004 06:54 PM
wizzards581
Feb 22, 2004 08:43 PM
mdj95
Jul 27, 2003 11:17 AM
joe_bocc
Jan 20, 2003 01:44 PM
