ls in eg?
You can use that engine, tranny, and electronics, but you'll need new mounts, new shiftlinkage, and new tranny. You need 94+ integra mounts, 94+ integra tranny, and 94+ integra shift linkage.
you will require a 94+ b-series tranny, with that 3x mounts already on the tranny, use the ones with the tranny...gsr or b16a tranny is prefered....
ecu from 92-5 ls/gs will do, also DX will work as well
shift linkage from the ls can be reused....
why cant i use the cable tranny dont they work in the eg i know that they make a conversion for it i have the actual integra so i just use the mounts from the teg and shift linkage too
gaydm
Feb 14, 2005 07:59 PM
