Swap help.
Old Dec 2, 2001 | 06:15 PM
STK B16's Avatar
Default Swap help.
ANyoen Located around Santa Clara, CA area that can help me on my swap.. i finish the swap.. but the car is havin some probs.. idles fine. but when i step on the gas pedal it dies.. Checked my plugs, wiring but still cant figure it out. email me me if u can COme out and take a look and help me.. thanks..
Old Dec 2, 2001 | 08:05 PM
shairacer's Avatar
Default Re: Swap help. (Json79)
what kind of swap did you do?...im in fremont
Old Dec 2, 2001 | 08:39 PM
STK B16's Avatar
Default Re: Swap help. (shairacer)
I did a b16a3 swap into 90si running.. a p30 ecu aswell
Old Dec 2, 2001 | 08:47 PM
STK B16's Avatar
Default Re: Swap help. (hondamongrel)
what could be wrong with it.. it was in running condition when i took it out of a Delsol..
Old Dec 2, 2001 | 08:50 PM
STK B16's Avatar
everything came out of my frends car. when he got into an accident. i pulled everything out from hiscar.. ..
Old Dec 2, 2001 | 08:51 PM
STK B16's Avatar
would it work if i try to plug in my 90SI ecu? with that swap./ i didnt want to try somethin to mess it up
Old Dec 3, 2001 | 08:39 AM
STK B16's Avatar
I have a pigtail harness so i can take it out and put my old one back if i wanted to..
Old Dec 3, 2001 | 08:42 AM
STK B16's Avatar
Shairacer. can u come out and take a look? Email me. JSon79@aol.com with ur number .. we can hook up.. i dont get off work til 7pm tho.. is that koo?
Old Dec 4, 2001 | 09:54 AM
STK B16's Avatar
hey guys i got it.. thanks... it was my wiring to the distrubitor...
Old Dec 6, 2001 | 11:04 AM
STK B16's Avatar
i gues its still wrong im gettin a 9 code on my ecu... my car juss died this mornin.. Anyone got a b16jspec dist i can get.. or Shai.. email me urnumber again.. i lost it..
Old Dec 6, 2001 | 12:16 PM
jeff652's Avatar
try switching the plugs between the MAP and TPS. if they are reversed, it'll cause the exact symptoms your describing
Hope this helps
Jeff
Old Dec 6, 2001 | 04:16 PM
STK B16's Avatar
Default Re: Swap help. (jeff652)
ok let me go home and try this.
Old Dec 7, 2001 | 05:33 AM
WICKED2's Avatar
New User
1. what wiring harness did u used ?
2. unplug the tps and your map sensor then start the car
3. i have a 89 b16a dist no plug tho
4.double check and color code on the dist i think u plug it wrong
5.try using u'r old ecu if u get the same prob. its not the ecu
6 double check your wiring
[Modified by WICKEDII, 2:38 PM 12/7/2001]
Old Dec 7, 2001 | 01:49 PM
hybridb18c's Avatar
New User
I agree with JEFF652
Good luck!
Doug
92'vxR
[Modified by hybridb18c, 10:50 PM 12/7/2001]
eg686
Jul 11, 2005 06:56 PM
civictunr_ls
Feb 10, 2005 05:16 AM
Just-Dumb
Apr 26, 2004 05:57 AM
STK B16
13
Dec 4, 2001 04:13 AM
