Help, No reverse Lights.
Old Nov 27, 2001 | 01:22 PM
Sloth's Avatar
New User
Default Help, No reverse Lights.
After doing a auto to manual swap I have no lights. If anyone has done this before, where and what wire do I need to switch/add/takout? I look in my helm's manual, cant seem to figure this one out.
Old Nov 27, 2001 | 02:18 PM
FAST94GSR's Avatar
New User
Default Re: Help, No reverse Lights. (Sloth)
first check fuse, second check if the reverse switch is working, its in the tranny. you can jump the wires to see if the lights come on.
Old Nov 27, 2001 | 11:13 PM
infinkc's Avatar
well you have to connect the reverse lights from the trany to inside the car. The reverse switch should be on the front of the tranny, with two wires comming off the switch. The auto used the shifter inside the car to select the reverse lights. So you basicly have to run wires from the tranny to where the shifter was in the car. and connect the wires that go to the backup lights, on side of the switch will go to the lights, the other to a 12v source. I believe the wire going to the backup lights is green/black if i can remember right. Just go to the trunk and trace the wires to the reverse lights. HTH
j_the_guy
Mar 12, 2019 04:18 PM
89 Ef Amzler
Lighting
Oct 9, 2009 08:57 PM
R_P_S_1_3
Sep 22, 2007 11:13 AM
Vinceg99
Nov 9, 2002 06:02 PM
ahc'monracing
14
Nov 6, 2002 03:59 PM
