oil pump replacement
Old Nov 27, 2001 | 05:00 PM
shingles's Avatar
Default oil pump replacement
I am looking to replace JDM 1st Gen B16. I was intially under the impressison that all B series are the same pump. Then I read that there are difference between OBD I and OBD II. So the question is, what should I use? a B17 pump? or 94 B16 pump from a Sol?
thanks,
-S
Old Nov 27, 2001 | 05:02 PM
DragII's Avatar
25 Year Member
Default Re: oil pump replacement (shingles)
the 94 Del Sol pump should be just fine.
Old Nov 27, 2001 | 05:14 PM
shingles's Avatar
Default Re: oil pump replacement (DragIIcivic)
Thank you sir.
-S
Cody Pereira
Sep 5, 2012 07:32 AM
almostjdmeg
12
Jan 28, 2010 04:54 PM
4gencivicef9
Apr 19, 2006 04:09 PM
94siturbo
Nov 2, 2003 03:16 PM
