B16 Axles, and intermediate shaft which works?
I have heard that GSR axles will work,
and I have read that the GSR intermediate shaft is too large for the B16 tranny,
So which is correct?
can I use a B16 intermediate shaft, and teg axles?
Re: B16 Axles, and intermediate shaft which works? (DragIIcivic)
i have a jdm b16 and i got a 90-93 integra intermediate shaft from a manual trans on mine because when i got the motor it didnt come with one. it bolts right up . if you are talking about a delsol motor or a civic si im not sure if they are the same. hope this was a help
Re: B16 Axles, and intermediate shaft which works? (internet ay)
It's a del sol motor, but yeah they should be the same. so it should work for me too.
which axles did you use w/ that shaft?
i bought mine from RAXLES which are premade hybrid axles which i beleive are 90-93 integra inner joints and 1st gen integra outer shafts this is in a crx with the hasport b series motor mount kit.
1 Post
You know that the intermediate shaft from a 90-93 (whatever he used) won't work with your application...he has a cable tranny while you will need to use a hybro...both have different intermediate shafts..
[Modified by fowler, 5:27 PM 11/25/2001]
Re: B16 Axles, and intermediate shaft which works? (fowler)
yeah, I'm gonna need the SI, or Del Sol Intermediate shaft, but I wanna know if i can use GSR axles with the Del Sol shaft.
Kusai.Nihonjin.Desu
13
06-23-2009 05:45 PM
juicy.koreans.suck
10
01-10-2002 10:47 AM
