GSR into EG
Old Nov 13, 2001 | 09:37 PM
Cory man's Avatar
Default GSR into EG
Helping out a friend: What wiring changes need to be made for a gsr swap into a sohc vtec powered EG? Just want to make sure that I am correct about wiring changes. Thanx
Old Nov 13, 2001 | 11:38 PM
Backyard Speical's Avatar
Default Re: GSR into EG (Cory man)
4 wires. Vtec (3) and one knock sensor (1)
good luck on the swap
Old Nov 14, 2001 | 12:34 AM
Charles B.'s Avatar
Default Re: GSR into EG (Prodigy 2.2 EK)
Dont ferget about the secondary butterflies.
Old Nov 14, 2001 | 04:32 AM
Kalokohan's Avatar
New User
Default Re: GSR into EG (SuperDuperEG)
Yup, but depending on the year of the GSR engine(OBDI or OBDII) the butterflies might be tricky. If it is OBDII, you have to reverse the polarity on the butterflies and switch pins A20 to A17.
Old Nov 14, 2001 | 10:08 AM
Spade's Avatar
Why would he need the Vtec wiring if he has a Vtec powerplant already in the chasis?
Old Nov 14, 2001 | 03:17 PM
Cory man's Avatar
Default Re: GSR into EG (Spade)
Should just be a knock sensor wire that I have to run. I assume that I use the stock sohc vtec engine harness. TIA
WiCkEdInTeGrA666
Feb 13, 2009 04:54 AM
ShadyTunerGTS
30
Sep 27, 2008 03:09 AM
F5sGsrHatch
Mar 15, 2007 07:33 AM
bigblock-EG
10
Mar 26, 2002 08:04 AM
