SWAP SHOPINGLIST NEEDED.....
Old Nov 26, 2001 | 11:07 AM
FLIP2daMaX's Avatar
Default SWAP SHOPINGLIST NEEDED.....
THE NEXT THREE MONTHS IS CRUCIAL....I NEED HELP FROM THE VAST KNOWLEDGE H-T MEMBERS HAS TO OFFER....
I NEED A SHOPPING LIST FOR A SWAP
I HAVE A LIST, I JUST WANT TO MAKE SURE I DON'T MISS OUT ON THE LITTLE PATS SUCH AS....HOSES AND AXLES AND THE SORTS........
thanx for your help in advance.......
oh....the swap is hopefully a JDM Si-G (b18c) engine in a 5th gen Si hatch.....
Old Nov 26, 2001 | 11:36 AM
Kalokohan's Avatar
New User
Default Re: SWAP SHOPINGLIST NEEDED..... (FLIP2daMaX)
If you keep the stock headers and cat, you will need to get that extended a couple of inches to bolt up to the exhaust. I have a testpipe that will bolt on if you want one until you get around to extending the cat.
Get a 94-95 GSR ecu, it makes everything easier.
IAB's polarity will need to be reversed and given a 12V signal.
Dual core, all metal radiator(not necessary but highly recomended, my crappy stock rad sprung a leak in 2 months)
Delslo DOHC Vtec A/C bracket if you plan to keep cool. Email me for part#.
That's all I can think for now, sige na pare, ingat.
Old Nov 26, 2001 | 01:02 PM
DR. ON POINT's Avatar
Banned
Default Re: SWAP SHOPINGLIST NEEDED..... (Guardson3r3)
how do u change IAB's polarity give it a 12V signal.
Old Nov 26, 2001 | 03:31 PM
FLIP2daMaX's Avatar
Default Re: SWAP SHOPINGLIST NEEDED..... (On Point)
good "?"
Old Nov 26, 2001 | 05:42 PM
B_CRUZ!'s Avatar
might as well get a skunk2 manifold. so you don't have to worry about the IAB stuff.
Old Nov 26, 2001 | 07:52 PM
karmannghia's Avatar
Default Re: SWAP SHOPINGLIST NEEDED..... (eg6_LHD)
Skunk manifold is good, but then you will have to spend another 300 bucks on a Holley throttle body to match the port of that manifold. So you looking at 600-700 bucks. Its like a domino effect......
Old Nov 26, 2001 | 09:03 PM
Charles B.'s Avatar
Hey I put a JDM Si-G in my CX. But I already had everything I needed because I bought the whole front clip.
Old Nov 27, 2001 | 12:28 AM
FLIP2daMaX's Avatar
Default Re: SWAP SHOPINGLIST NEEDED..... (SuperDuperEG)
bought the whole front clip?....soree, but what is the whole front clip?....
"dyam i'm half asleep if i get flamed for this"?", then s'all good"
Old Nov 27, 2001 | 12:36 AM
Charles B.'s Avatar
The front clip is the the whole front end of the car. From just behind the shifter and up. Mines didnt come with the seats, doors, wheel, windhshield, or wheels. However, it did come with the whole entire motor (which has never been taken out of that engine bay prior to me taking it out) including complete A/C, power stearing, radiator, blah, blah; front bumper, headlights, stock fog lights, hood, fenders, RHD dashboard (including cluster, climate control, shifter, blah, blah; and also the whole front suspension. I got all this for 4500.
Old Nov 27, 2001 | 07:26 AM
Kalokohan's Avatar
New User
You have to take the black wire coming out of the IAB and give it a 12V signal, use the blk/yellow wire that power the injectors and switch ECU pin A20 to A17. You can also email 92SleepR to get detailed instructions. I haven't had the time to do this but I will be calling him soon for help. He works in DC but his peeps are in McLean. I live in Fairfax and you live in The Bridge, we can work something out.
Old Nov 27, 2001 | 10:13 AM
Banned
well im doing a ls swap so i dont know if i need to reverse that polarity....know anything i dont?
Old Nov 27, 2001 | 12:01 PM
Kalokohan's Avatar
New User
Nope, I don't think the LS engine has the same intake manifold set up like the GSR's. What car are you putting it in?
Old Nov 27, 2001 | 07:38 PM
Banned
im putting it into a 96 ek
Old Nov 28, 2001 | 07:40 AM
Kalokohan's Avatar
New User
Cool, I think the LS has a different intake manifold, I'm not sure though. You frankenseining it?
Old Nov 28, 2001 | 08:13 AM
Banned
n need fr frankenstine when u have turbo...psht(blow off valve noise)
Old Nov 28, 2001 | 09:35 AM
Kalokohan's Avatar
New User
I feel ya. I have 1/3 of the money for my turbo kit. It will probably take another year for me to save up the rest. I want a 10 second turbo hybrid, so far I have a 13.5 second N/A hybrid.
Old Nov 28, 2001 | 09:37 AM
Banned
10's are to fast for me...what u got in ur hatch now?
Old Nov 28, 2001 | 11:15 AM
FLIP2daMaX's Avatar
running 13's on a hybrid?.....dyam that's my goal.....
what is u'r setup?......chasis?, engine?, and mods?....
i was opting to put a CTR head on the Si-G bottom.....how does this application sound?.....iz this hard at all?.....
Old Nov 28, 2001 | 11:48 AM
Kalokohan's Avatar
New User
93 Civic Hatch CX
00' B18C1
I/H/E
ACT 6 puck
Testpipe
Skunk2 P28
Slicks
Old Nov 28, 2001 | 01:07 PM
fowler!'s Avatar
Are you running a Skunk2 manifold? Or stock?
Old Nov 29, 2001 | 07:38 AM
Kalokohan's Avatar
New User
Default Re: SWAP SHOPINGLIST NEEDED..... (fowler)
Stock.
Old Nov 30, 2001 | 09:29 AM
92sleepR's Avatar
New User
Hey Guardson, When are you planning on going turbo? I have been fantasizing about building a custom setup aroung a Hytech street turbo manifold (yes, i have expensive tastes). I would like to compare notes.
Mike
Old Dec 1, 2001 | 03:14 AM
FLIP2daMaX's Avatar
AIGHT Y'ALL I JUSST HAD A CHANGE OF HEART
i'm gonna save for a B18C spec-R
not the Si-G
i thought about it and figured that w/ the mods i wanted to do to the B18C, i was gonna end up spending just as much, if not more, as to just getting a JDM spec-r
any thoughts on this change of plans?
Old Dec 1, 2001 | 11:00 PM
Halo's Avatar
B18B uses single runners, just like the ITR
Castillo847
Oct 3, 2009 06:42 PM
spontaneous ep3
Aug 26, 2004 08:41 PM
Peter K
Mar 17, 2003 10:05 PM
