master cyl. swap for EG
i want to swap out my CX ones for an integra one. but what i want to know is, is it a direct swap? if not what needs to be modified? is there a difference between an LS, GS-R, and type-r?
THANX TO THOSE HTH!
THANX TO THOSE HTH!
Re: master cyl. swap for EG (eg6_LHD)
The ls MC and booster will bolt on. The ITR and GSR will need to be modified since they have abs. The lines coming into the R and gsr are on different sides. The LS is 15/16 of an inch. The other 2 are 1 inch. If your going to swap out the MC, might as well swap the proportioning valve. I distributes the amount of fluid going to front and rear calipers.
New User
if u can just get the ITR. just need to bend the hardlines a little bit. but u dont need to flare the line like u would on the others: LS/GSR
New User
are u swapping to bigger brakes? if so it is a must in my opinion. there will be far less pedal travel with the larger mc/booster. HTH's
4DALOOKS92
04-18-2009 02:58 PM
4DALOOKS92
04-06-2009 12:00 PM
SuicideSlide
06-28-2004 11:36 PM
singlecam screamer
08-08-2002 09:01 PM
905_S2K
06-19-2001 11:50 AM
