CX to EX
Old Nov 20, 2001 | 04:18 PM
itr0032's Avatar
Default CX to EX
I have a 92 CX and I'm putting in a 93 EX swap in.What will I need to rewire?Will I need any other parts,motor monts ect?The CX has 233K on it,and it's a winter beater,so none of that put a GSR or SI motor in......I"M POOR Thanks
Old Nov 20, 2001 | 04:26 PM
eg6ajk's Avatar
Default Re: CX to EX (itr0032)
2x vtec wires and ground will need to be added into the harness since its a 92, you can just added it into the shock tower plugs or use EX engine harness
02 wires will need to be added since it uses a single wire vs. 4 wire for Si...unless again you reuse the EX harness....
also reuse the EX tranny, which has much better gearing, get the ecu (p28), use the d16z6 header and even exhaust if you can...
cluster is also optional, but well worth it...
Old Nov 20, 2001 | 04:31 PM
itr0032's Avatar
Default Re: CX to EX (eg6ajk)
I have the EX harness
wernhersey
Oct 13, 2006 12:48 PM
2DoorBandit
Mar 27, 2006 05:36 AM
duggy
16
Mar 18, 2006 03:54 AM
LDxShyGuy
Jun 1, 2003 11:07 PM
itr0032
Jul 9, 2001 08:06 AM
