CRVTec mounts
Old Nov 25, 2001 | 02:05 PM
SlowEX's Avatar
New User
Default CRVTec mounts
All you guys running B20 Swaps what motor/Tranny mounts did you use? Anyone offer aftermarket for an EK?
Old Nov 25, 2001 | 04:40 PM
Halo's Avatar
Default Re: CRVTec mounts (SlowEX)
if you have an Ek then you don't need a mount kit for any B series
Old Nov 26, 2001 | 09:31 AM
SpeedMonkeyRacing's Avatar
Default Re: CRVTec mounts (Halo)
huh? EG you don't need mounts...EK you do
Jeff-
Old Nov 26, 2001 | 01:14 PM
civic_hb96's Avatar
Default Re: CRVTec mounts (Corporal-Jeff)
huh? i just used stock Si(R) mounts.
Old Nov 26, 2001 | 02:34 PM
SlowEX's Avatar
New User
I've heard alot of different stories. Some say stock will work some say I need the upper engine and tranny from 99-00 SI others say LS. So are they all the same. I find that hard to believe. So I'm dropping a B20 Vtec in a 97 civic coupe. Technically if I just locate all mounts from a 99-00 SI I should be safe between those and stock? Right? Sell off what isn't needed. Planning so I'm not down for more than 2 weeks.
I've been a pedestrian here for quite awhile and I know there is alot knowledge here so give it to me....Please?
Info....Info....Info....
Just found this in another topic and I think this answers it
Posted by "bodykit=rice"
all 99-00 si brackets except the upper trans bracket and drivers side liquid mount you can use your stock ones..
The B20 and B18 block are externally the same (I think) So that should do it.
Thanks
Matt
[Modified by SlowEX, 11:41 PM 11/26/2001]
knappy03
Jul 28, 2011 12:49 PM
EKlp
Dec 29, 2007 01:18 AM
EKlp
May 6, 2007 01:08 PM
atmosphere
Apr 11, 2006 07:21 PM
