To those with obd2 engines in an EG
I have a 96 obd2 gsr engine in my 92 cx. i'm getting a check engine light and i know its because i hacked my wiring. well anyways i'm getting it professionally rewired and my question is:
is it better to have the obd2 engine wired for my obd1 computer, or rewire it so i can use my obd2 computer.
is there anything special i need to know
thanks
-Craig
thanks
-Craig
Re: To those with obd2 engines in an EG (neumonik)
Buy yourself a usdm P-72 GSR Obd1 ecu. It plugs right into your cars wiring harness. Its easier than trying to use an obd2 ecu in an obd1 car.
Re: To those with obd2 engines in an EG (djay86)
Hondata is a standalone ecu. I have a 2000 b16. I am wanting to put it in my 90 std civic. Should i switch to an obd1 ecu or obd0? I have been told it is too hard to use the obd2 ecu in my civic.
i know this sounds mad newbie, but what the hell is a hondata
New User
Re: To those with obd2 engines in an EG (Hayasa15)
As for your set up. Get the wiring fixed and use an OBD1 GSR Computer (or a Hondata modified one) That will be the best for taht particular engine. The Hondata will allow you to change various parameters as you modify the engine so it's a worth while investment.
Mike
Re: To those with obd2 engines in an EG (jdm5ghb)
If you can't get an ODB1 P72 to run right, adding a Hondata on top of it is just going to multiply your headaches.
Re: To those with obd2 engines in an EG (JeffS)
JDM:
I also have an obd2 motor with an obd1 ecu.. I dont have any driveability problems at all. The car gets 32 mpg mixed driving. I have an obd1 JDM ecu, the mileage is about 3 mph less. If your car is running fine, then leave it alone or chip your ecu.
mitchell_2kSiR
12-30-2007 09:32 AM
