what will happen if I retard timing all the way?
I know if you advance to a point you will hear detonation, but what if I retard all the way? I am wondering this because I will be running 12:1 compresion pistons and I want to retard it all the way So I dont detonate. Good Idea or bad?
Re: what will happen if I retard timing all the way? (rainforest)
so I should do this right away and then slowly advance the timing right? intill I here detonation then I should back off. Right?
Re: what will happen if I retard timing all the way? (infamousRRH)
What are you using for tuning? With 12:1 compression, I hope you are using a stand alone. Let us know what your setup is so we can better help you.
Re: what will happen if I retard timing all the way? (SlowCivicDX)
I will break her in with a p28 mated w/mugen chip then I will go hondata stage3, here is my setup if this better helps you. https://honda-tech.com/zerothread?id=149535
[Modified by infamousRRH, 6:15 PM 4/6/2002]
blazin
12-02-2001 07:58 PM
