To TPS or not to TPS, that is the question.
Old Apr 5, 2002 | 06:10 AM
D1ANCER's Avatar
Default To TPS or not to TPS, that is the question.
I just put a 1st gen B16A1 into my EG. When I turn the car on the check engine light comes on and it is a code 7 for the TPS. I am using the TPS off of my DX because the one for the B16 was broken. When I put the DX TPS on, it forces the engine to idle as high as 3,000. When I take it off, the check engine light is still on, but the idle is a little lower. Is it safe to run without a TPS? Will a DX TPS work the same as a B16A1? What should I do to get rid of this check engine light.
Old Apr 5, 2002 | 09:16 AM
Jackson's Avatar
Default Re: To TPS or not to TPS, that is the question. (D1ANCER)
you need the tps sensor. are you sure you didnt switch the map and tps sensors by accident? are they wired up correctly? i have never tried a d-series tps on a b-series tb, but i am sure they work together.
Old Apr 5, 2002 | 01:25 PM
Kamin's Avatar
Default Re: To TPS or not to TPS, that is the question. (Jackson)
yea you need a tps sensor. mine was bad during my swap too. same problem. 3000 idle.
the throttle response without the TPS is unbelivably bad. try it. there is a HUGE delay.
get a tps. make sURE you align the one off the d series motor with the intake manifold. it should work but i might be wrong.
got00rice
Dec 30, 2009 12:16 PM
Tizzakowack
Dec 12, 2008 02:06 PM
hurleypooper
Apr 29, 2008 08:12 PM
Fatcobra
Jun 9, 2006 04:50 PM
JAMinCiViC
Aug 12, 2002 04:08 PM
