Which Intake?
Old Apr 3, 2002 | 07:59 PM
89HF's Avatar
New User
Default Which Intake?
Would an intake designed for an ITR work in an EG w/a JDM B18c5 swap?TIA.
Old Apr 4, 2002 | 07:19 AM
SCsol's Avatar
Default Re: Which Intake? (89HF)
if its for a ITR it will fit on a ITR are you worryed about room you shoould have enough
Old Apr 4, 2002 | 12:39 PM
hybridreams's Avatar
You would have serious rubbing issues and have a hole in the piping in no time. 99-00 Si CAI is the perfect fit you want.
Old Apr 4, 2002 | 01:31 PM
B_CRUZ!'s Avatar
Default Re: Which Intake? (hybridreams)
yeah what he said. and FYI there is no such thing as a JDM B18C5
Old Apr 4, 2002 | 01:49 PM
hybrider's Avatar
Default Re: Which Intake? (B_zurC)
99-00 si
Old Apr 4, 2002 | 06:26 PM
89HF's Avatar
New User
Sorry-It's a JDM B18cR.'99-'00 Si CAI is 2.75",correct?And ITR CAI is 3" diameter,right?I know the Si CAI will fit the ITRs TB using the silicone coupler,but will it give the B18cR enough air?TIA.
[Modified by 89HF, 9:30 PM 4/4/2002]
Old Apr 7, 2002 | 09:44 AM
89HF's Avatar
New User
Anyone?Bueller?
Old Apr 7, 2002 | 09:49 AM
Well it'll give more air than your stock air box. Up to you if you want to go through the hassle of modifying an ITR CAI to fit.
Old Apr 7, 2002 | 10:37 AM
89HF's Avatar
New User
Enlarge the hole in the chassis that the intake tube runs through while the D15(old)is out,trim the hole w/split vacuum hose(no metal on metal rubbing;did this on my CRX)-any other fit issues?TIA.
Old Apr 8, 2002 | 09:23 AM
89HF's Avatar
New User
OK-I'm a dumbass!A friend told me that Civic CAIs go through the hole that the stock air box sits on(like my old CRX),while Integra CAIs go under(?) the frame horn or rail.Any thoughts?Will a CAI for an Integra Type R work in an EG?TIA.
garagespecial
11
Jul 10, 2003 06:23 PM
ksb
Mar 11, 2003 03:58 AM
E. Honda
Jan 20, 2003 08:57 AM
jdm4life
Nov 19, 2002 05:59 AM
chronic
Sep 6, 2002 11:17 PM
