Help on a EK swap!!!
Old Apr 5, 2002 | 07:17 PM
Soku1kcivic's Avatar
Default Help on a EK swap!!!
Hey i have a 96 civic HB cx and iam swapping in a B16A2 from the 00 SI and iam wondering do i need new mounts, will i need new a/c stuff or can i use my CX a/c compressor and wires,next is what distrubutor should i use,and i have the 96 ex wire harness i know SOHC sure doesnt work on a DOHC.
Thank you for your help
Old Apr 5, 2002 | 07:50 PM
Default Re: Help on a EK swap!!! (Soku1kcivic)
Old Apr 5, 2002 | 08:29 PM
Well i found out on the mounting part it should fit but can some one help me on the distrubutor and the a/c
Old Apr 5, 2002 | 11:03 PM
Jackson's Avatar
this topic has been covered thousands and thousands of times. just do a search.
Old Apr 5, 2002 | 11:48 PM
Buzz's Avatar
New User
Default Re: Help on a EK swap!!! (Jackson)
Mounts
Driver side- Use the mount bracket I mentioned above. This piece bolts to the block below the cam gears. reuse the civic studs. Also, use all other civic parts at this location. (picture)
Rear tranny- Use the rear upper tranny bracket I mentioned above. Use the stock civic rubber mount. (picture)
AC Bracket- Use the ac bracket I mentioned above and reuse the civic stud and rubber mount. Integra piece is similar but won't work. (picture)
Front tranny bracket- Use integra piece on the tranny but civic stud and rubber mount. Integra stud and rubber looks the same but won't work.
Upper tranny mount- Use all the civic pieces.
If you do keep your ac, there is no need to discharge the system. Simply unbolt the ac compressor from the D motor before you take the D motor out of the car and strap it out of the way. When you put the B motor in the car, with the correct ac bracket, bolt the ac compressor back to the motor.
Also, nothing else from the D motor can be used including the tranny, axles, ecu, shift linkage. It won't work so throw it away.
Old Apr 5, 2002 | 11:53 PM
poison's Avatar
no u don't need new mounts, although it wouldn't hurt to get better ones.
as for the a/c, no u don't -- undo the lines and put them into the b16's a/c compressor, no need to discharge the freon. and you can use everything that the b16 came with, it should mostly be plug and play, i believe u need to add knock sensor from the engine harness to the ECU connector, then plug it into the b16a's ecu.
Old Apr 6, 2002 | 12:34 AM
THanks for the info but i still need help on the distrubutor iam using the 96-98 ex wireharness i know it doesnt fit so should i rewire or use a different B-series motor distrubutor like a OBD2 one??
Old Apr 6, 2002 | 10:24 AM
Jackson's Avatar
get a 96-01 gsr, itr, or 99-00 si distributer.
Old Apr 6, 2002 | 02:12 PM
THanks
chicows18
May 24, 2012 08:27 PM
pinoyboy204
10
Apr 26, 2006 10:09 AM
siffredi
Apr 19, 2006 05:39 PM
atmosphere
Apr 19, 2006 02:30 PM
Lucky-R
Mar 11, 2005 12:08 AM
