help b16 question
Old Apr 2, 2002 | 07:48 PM
out2wincrx's Avatar
Default help b16 question
put a b16 in to 91 crx si had 90 integra axles driver side was to long tried to use 86 thats was even longer i heard i need 91 integra halfshaft because its a little shorter true or not true answer needed asap thanx
Old Apr 3, 2002 | 10:58 AM
Redline130's Avatar
Default Re: help b16 question (out2wincrx)
If you are using 90-93 Teg axles, then use the 90-93 halfshaft. Don't forget to take out the spacer on the hub too.
Old Apr 3, 2002 | 11:11 AM
out2wincrx's Avatar
Default Re: help b16 question (cyber13)
so if what if i use 86 to 89 teg axles can i use the halfshaft that comes with the engine ?
Old Apr 5, 2002 | 04:51 PM
out2wincrx's Avatar
need help 86 to 89 teg axles fit but still getting a shake or vibration driver side wheel when i go down the road just wondering if the axle could still be to long or what help?
cadwiese
Feb 19, 2010 09:19 PM
mikester1222
Jan 22, 2007 06:11 PM
thatbluecrx
Oct 11, 2004 02:11 AM
SkunkCrxSi
11
Jul 19, 2004 11:54 AM
jondancer
Sep 1, 2003 01:20 AM
