Vtec engine into 92 integra rs- ecu and wire harness?
Can I use a 92GSR wire-harness & a 92 GSR ECU to complete the swap into my 92 integra RS with either BC1 or B16a2. Is it correct for me to assume that I won't need to run a separate wire from the Vtec solenoid. Thanks!
Re: Vtec engine into 92 integra rs- ecu and wire harness? (rainforest)
Someone just told me that even with the 92 gsr wireharness and the gsr ecu, i will still need to run the three wires to the ecu. Is this correct? Please help me out. Thanks!
Re: Vtec engine into 92 integra rs- ecu and wire harness? (cyfiro)
thats is true because you dont have the wires leading from the engine harness to the ecu. hope that helps
