B16A1 Cable trannys
Old Apr 4, 2002 | 06:22 PM
meept's Avatar
Default B16A1 Cable trannys
Is the search broken? I can't find anything at all on cable transmissions... Anyhow...
My JDM S1 transmission is making terrible noises in neutral, and I figure I may as well replace it, since I need to use the car. Does anyone know of a place that'll sell JDM transmissions without the motor? Every place I've called says it's motor+trans only (Nippon motors, Inline4, Importbuilder, ImportAutoSalvage...etc.).Alternatively, is there a USDM cable tranny that'll work with an 88-91 B16A? I had heard that the 90-93 Integra would work, but I can't find anything like that in the search either
I'm still searching the net at large, but if anyone has any interesting suggestions, post 'em up.
[Modified by meept, 10:25 PM 4/4/2002]
Old Apr 4, 2002 | 07:37 PM
B16CRX's Avatar
Default Re: B16A1 Cable trannys (meept)
A 90-93 Integra cable tranny will work. You can use any b-series cable tranny.
Old Apr 4, 2002 | 07:50 PM
Urban Business
Guest
Posts: n/a
Default Re: B16A1 Cable trannys (B16CRX)
yep
Old Apr 5, 2002 | 05:48 AM
meept's Avatar
Default Re: B16A1 Cable trannys (TorteX)
Thanks guys...now it's off to scour the salvage yards
Old Apr 5, 2002 | 08:49 AM
VTECVillain's Avatar
Any of the 90-93 Integra cable tranny's will work. If you want to have the same gearing as the one you have now, then you'll want to find a US 92-93 GS-R tranny. The LS tranny will have longer gears - better for a turbo if you plan on going that route.
Old Apr 5, 2002 | 10:31 AM
meept's Avatar
Default Re: B16A1 Cable trannys (VTECVillain)
Thanks for that tip...I'm staying N/A for the time being (unless I get a sudden flood of cash into my bank account!). Am I going to have to mix-n-match axles with any of the 'Teg trannys? The car has Raxles hybrid ones on it now...
Old Apr 5, 2002 | 02:48 PM
iwhichisme's Avatar
yeah try and find one from a 93 gsr, nice gearing, and will accept a better final gaer, as well as lsd. wish i had on done that!!!
Old Apr 7, 2002 | 12:49 PM
from_zer0's Avatar
Hey, I may soon be in a similar boat. My JDM cable trans for b16 is grinding 3rd/4th.
I know you can get a newer hydraulic trans put in there, but it'll cost you a few hundred more. That does give you some more (and definitely newer) choices for replacement. Maybe even a late model 'R' trans w/LSD stock. That'd keep your gearing similar (if not the same) and factory honda LSD.
This is what I may do if/when the tranny locks up, or absolutely needs replacing. I'm looking into going b20/vtec and I think I'd need a newer trans to bolt up to the late model motor.
Anybody wanna support or shoot down my theories? Please do, I'm here for the knowledge.
Old Apr 7, 2002 | 03:31 PM
misledyouth's Avatar
New User
Default Re: B16A1 Cable trannys (from_zer0)
u hsould be able to contact any engine importer aka jhp or hondamotorsonline and i htink they will be happy to set you up with a cable tranny. It may not say on there websites but i am positive most will sell just the tranny's. The only thing when buying a cable tranny is that you are taking a risk cause you have to realize there all at least 8 years old if not older.
Also if you do b20vtec you should stick with your cable tranny it will bolt up u just have to make sure to order the pressure plate for the b20 or b16 hydro tranny and then get the actual clutch disc for a 90-93 teg cable transmision. Then everything will be fine and dandy and go smooth cause the cable tranny splines and the hydro tranny splines are diffrent.
later
jesse
Old Apr 7, 2002 | 07:24 PM
rca90gsx's Avatar
We tried a hydro tranny from a 99 SI to mate up with our B16a1 engine, the input shaft was much different diameter than what the B16a1 would accept, the new tranny was a much smaller diameter.
Richie
Old Apr 7, 2002 | 10:56 PM
court's Avatar
25 Year Member
Default Re: B16A1 Cable trannys (rca90gsx)
you just need to remember 2 things
89-91, small spline
92-01 big spline
splinne size is clutch dependent, or actually co-depenedent, not moto rcompatibility
Old Apr 8, 2002 | 12:47 PM
Jeff C's Avatar
Default Re: B16A1 Cable trannys (court)
court,
Does that hold true for jdm tranny's also? If this is so, according to what you are saying, if I have a 92-93 Integra clutch, then I cannot use a 89-91 jdm y1/s1/j1. Right?
Old Apr 8, 2002 | 04:43 PM
court's Avatar
25 Year Member
Default Re: B16A1 Cable trannys (Jeff C)
yes, if you are running the input shaft that stays true with the transmission. however, if you are running a big spline on a j1( JDM! 4785) then your setup would agree with the input shaft(final drive)
HondaBurger
Jun 20, 2007 01:37 PM
AWDspyder
Aug 10, 2005 05:06 PM
r north
Apr 18, 2004 04:03 PM
joey1320
Feb 20, 2003 01:19 PM
jdmIScool
Aug 21, 2002 07:18 PM
