ls/vtec, which headstuds
hi i am doing an ls/vtec and i am doing arp head studs and i need to know what motor to get them for , i seem to remember that someone said to get b18c ones but i could be wrong, and also should i use an oil pump from a vtec motor because the motor is being built right now and i need to replace it and by the way the motor will be turboed so i was thinking i might need the extra oil pressure . thanks
Re: ls/vtec, which headstuds (WAFFLES)
yes use the b18c studs. the b16 studs are too short and might cause you to blow a headgasket.
