- D series air intake manifold on a b series
- B20v help needed
- Ring end gap for b16a 81.5mm
- B20v what cam I can use
- Bolt ons for Non VTEC B20B
- STOCK MOTOR REBUILD
- Dyno Expectations
- 2.1L B18 all motor build
- Small nicks on rear main journal
- Skunk 2 Intake and TB on a y7
- exhaust bottleneck and power loss ??
- B20 405a2 set up
- 07 ridgelne noise and oil blowing advice please
- H22 vs b20v
- B20V drag CRX revs to max RPM upon start up.
- Recommendations to start tuning with HTS and cobraRTP
- Most modern B18c Cam lobe profiles
- Honda JDM CRX Si ZC motor
- Trouble getting catalyst and evap monitors ready for emissions testing
- Intermittent P0977 with VSA Light and Flashing D, Limp mode
- BC Stage 2 cams supporting mods?
- PR3 Head
- 1982 ACCORD EK1 oil leak
- Genuine Honda parts vendor
- Compression ratio?
- B Series Head Swapping
- BTCC honda accord 98-02 CG
- Will a fully built b18 pass CA Bar or emissions?
- Occasional White Smoke from Rebuilt B18C1 Engine
- Small B series intake manifold?
- Identify a loose camshaft maybe?
- VTC actuator - leave as is?
- Need help on cam choice….
- B18c burning oil even after replacing all valve train seals
- Camshaft upgrade, have I got everything?
- Made a better B16A.
- Antifreeze for 1988 Civic 1.6L
- b20v crank pullley question.
- EVAP Canister & Hoses
- n/a b20 with ls tranny cranking not starting
- b16a power goals
- Swapping to a EG Chassis
- Blox Type C cams issue
- Any way I could get a B20 to 300 HP N/A?
- Fuel issues after tuning.
- Vaccum line tied up, why? B18B1
- Troubleshooting; intermittent Tick in top end D16Y8
- 2012 Civic 1.8L timing issue.
- B18c4 spark plugs different thread lengths?
- B20b b16 Tran oil issue
- B16A - Burning oil - Please help!
- D15Z6 engine hesitation when gas pedal depressed/released
- integra air intake top fuel 1000 power chamber
- Ek hatch with a b20v
- B20v in Ek hatch
- Basic B16 Build; what else should I do while it's out?
- MiniTec Wiring Harness - VTEC issues - B18C4
- 1991 Legend II (KA7) 3,2i
- p3000 code issues k24a1
- 0 Valve Lash Question
- Flush CVT by draining the radiator cooler
- H23A APB - Help find the "tagger" -
- mini-me Y8 build questions. Cams?
- B16a3 with 12.0:1 pistons
- B20v cams gear issue or adjust
- B series Fueling
- Anyone running AEM SERIES 2 k24a2
- 97 ek hatch build b20v issue
- Temp gauge rising when hvac slider is cold
- Skunk2 cam code unknown
- B18 build! Pondering b18a1/2 and vtec or not
- Civic B18c type R Needing some Help
- 2000 Accord 3.0 Gas and Return Lines
- Del Sol Won't go past 4k RPM
- B18c1 ( GSR ) Build need some info
- Weird idle/ stall
- B20z2 na build
- D17 Stock Internals
- cb400 vtec2 valve seat cutter???
- Proper Metric Bolts for B16 Damper Removal?
- H23A DOHC VTEC Blowby
- Swap
- 00 CBR600 F4 fuel pressure
- k24/k20 high comp
- Another Newbie Looking for Advice (B16/20)
- B16 vtec valve to valve clearance
- B20v wire harness issue
- 86 EW1 Head Question
- Worth it to get vtec head on a stock b20 lowcomp?
- AEBS Intake manifold
- Power mods for a low comp b20?
- B20v oil leak after brand new motor
- B16a with CTR pistons
- Can missing Lmas cause damage? - JDM b16a gen 2
- NEWLY BUILT B20V SLOW
- Help identifying B-Series Cams
- D16y8 Vtec Mini Swap All-Motor Build INPUT WANTED
- B20v injector issue
- Mystery B18C asking for help
- Fully build b20v fuel pump issue
- K series manifold into a B series gsr
- H23 blue top with aftermarket h22 pistons
- B16a - peak HP with skunk2 tuner 1 cams
- H22A balance shaft delete
- B18b1 vtec head swap?
- Newbie here looking for some advice.
- V6 oil pump leak
- Frenkeinsten b20b engine
- skunk2 tuner2 version 1 cam degree specs for B-Series
- I have a head with fresh valve job but want to swap valves. New valve job needed?
- Coil on plug questions
- Will 3inch exhaust be okay for now? - N/A B16a
- B series hondata CPR spark plug recommendation
- Parts compatibility
- Idle problems 02 accord
- B20V expected power
- B16a - expected BHP figures with Skunk 2 cams?
- Stock ECU Alternatives/workarounds
- B18C5 Differential problem?
- Ignition Timing H22A7
- D series Engine mounts general enquiry..
- Noise coming from intake manifold hose ? Help !
- B18c1 gsr, white smoke above 3500 rpms?
- Skunk2 tuner 3 cams degreeing
- ek3 mine me swap
- Honda integra type r Header
- sprayed water under the hood to clean bay now fuel pump does not prime :(
- engine isolater for 1989 acura integra
- Need help finding engine mount 50820 sd2 960
- The cursed b18c overheating
- How to set up breather box for a block that's already had the pcv box deleted?
- Stock 94 gsr misfire
- Need help v6 engine and auto transmission
- D16b5
- Engine mount help me!
- Smoke coming from exhaust and engine
- 1991 civic zc to b20 swap
- Help choosing new cams
- Clutch?
- Need help
- Piston-valve clearance with F22a/F23a hybrid
- Stripped Valve Cover Bolt Threads - Time-Sert or Helicoil - Bolt Size and Thread
- honda civic jerks strongly at slow speed.
- overcammed with skunk2 pro 3's
- CAM I.D HELP LEASE.
- Is this Skunk2 Camshaft CARB sticker real?
- HELP HELP MF'rs 2016 ACURA MDX RANDOM MISFIRES INTERMITTENT HELP
- Smoke from Exhaust at startup
- Safe Rev Limiter on a H22A
- Help with Fuel pump in 1990 Integra
- Valve issue! Sunken valve seat?
- 2005 Honda Civic SE
- J30 broken rocker arm?
- v6 coupe transmission problems(need help fast)
- B20Vtec Oil Catchcan setup
- LS Vtec in a eg hatch bone stock with 1000cc injectors and 255pump need help!!!
- TD-62U Dizzy
- Ignition timing
- d16y8 not running at low throttle aperture
- B20 Vtec Tuning
- Burning Oil! - B16A
- 98 honda civic no spark no fuel
- H22A Block H22A4 Head
- 98 civic D28Y8 no spark
- B20v question
- Conversion to Crank-Fired ignition
- Need your help identifying D-series camshaft
- JDM Integra Type R pistons (P73-J00) in GSR... Compression Ratio?
- b16a2 head on GSR Block
- B20v crank ?
- Stage 2 Cams / built head with stock pistons?
- LS Vtec build: Use the LS or GSR crankshaft for 9000 rpm?
- D16W1 engine - any alternate replacement EGT sensor? Or info about it?
- B16 dual spring issue please help
- B16 head issue
- Suggestions for removing a crank pulley
- Misfire/low power after warm up below 2500 RPM on 1991 Honda CRX
- ITBs and IACV w/ S2 IACV Relocation
- 1998 civic D14A4 noise
- Dohc zc engine help
- H22 All motor build questions
- LSVtec b16a hose help
- Is it time for a TB or intake manifold upgrade
- Do more or stay
- Buddy Club Spec IV Cams: Thoughts on My Build Plan?
- Can anyone Id this h22 header
- IDENTIFY HEAD CODE
- D15y7 bolt ons
- LSvtec 600-700 rpm idle surging
- J35A7, Broke timing belt, New heads or engine?
- I need help building my b18b1
- Anybody have any experience with the crate engines from JEGS?
- F22B1 Rotating Assembly
- No notch H beam build
- b Series best header
- Motor Machine shop help request
- What does it take for a B18B1 to make 250-300whp?
- Dyno result for rebuilt 1991 Prelude b20a6 + seeking advice
- 96 Gsr kick panel wiring connectors HELP
- JDM motor
- 2013 Acura TL NA build
- Peckurz's LS VTEC Build Questions to hit 10,000 RPMs. What else do I need?
- My 1st N/A Motor Build
- What is this on the surface of my block? And how do i remove it?
- Selection of engine equipment for d15b
- Drag Cartel 005.5 Killer Cams Timing Help
- Feedback Request: Nippon aftermarket PR3 Pistons.
- Oil Pressure Relief Valve Issue? *SOLVED* Loose oil filter
- Buddyclub Spec VI 6 camshafts
- B16A2 N/A Build
- 1995 del sol cranks but won't start - Possible bad compression?
- Having a weird power loss issue.
- H23A w/ BC Stage 2 Camshafts: Cam Degreeing
- Overheating issue with my B18 motor
- Finding alternative to compensate detonation/Knocking for increased compression ratio
- tps calibration question
- What coolant hoses do I choose for an F20B engine in an EM1 chassis?
- Assistance needed: b18c1 spark or timing issue. Where do I start?
- Strange issue with my b16. (losing power/jolting/poor idle).
- Assistance Needed: Swap B20z2(Auto) to JDM B20B. What is required?
- 11,000rpm B16 destroyed a piston. Any diagnostic theories to discuss?
- Engine Block Crack or Casting Marks
- Is a J Series question ok?
- zxpro is planning a B16A SIR2 All Motor for "Track". What are some options?
- 405 stock block
- eg6noise's reasonable budget B20VTEC build plan. Suggestions welcomed
- Resurfaced Block Has A Chip!!!! :-/
- F20b sohc vs dohc
- 86 EV E-series engine timing belt help
- Proper fuel injectors
- Ported f20b head and intake manifold
- help figure out this noise 8th gen 3.5L
- Apexi VAFC HP Gains Stock B18/20 Non-VTEC
- Fuel Pressure Regulator Comparisons. Are there any differences in "hp"?
- Ls/Vtec with rdx injectors. What is needed?
- D series itb shenanigans
- Crower cam spec questions
- Suggestions Needed: Running B20/VTEC. How should I run an Oil cooler?
- 4th gen TL J37 Oxygen sensor disabled
- Black oil in B16 head cam bore
- Feedback & Suggestions on Jag0's 230whp B20/VTEC Project Build
- Valve guide damage
- JDM ITR Pistons + GSR Rods vs. Forged Internals
- Putting a vtec rocker assembly in a non vtec head
- Need Help-Dead Cylinder-Oil Fouled
- How hard is it to build a dy16, b16, b18 or k-series?
- How to go about b16head and b20 block?
- B18c skunk2 pro 2 Hp numbers
