Ecu Pinout/ Function for p2t ECU "A" plug 32p (did search please click)
I put a 99-00 si motor and engine harness in a 96-98 civic that had a gsr harness and ecu in it. With the engine harness from the si I filled up plugs B and C in the P2t civic si ECU but now im running into a problem with plug A there is none bc it was part of the GSR engione harness and not part of the SI, I have an SI dash harness that has the A plug but its installed on another car and is becomming a bitch to get out. I'm just wondering whats the best to do. What are the functions of the things in Plug A what do i need and not need my first swap im lost!
Heres a list of the pins i have (researched that much)
A03
A04
A06
A08
A10
A16
A17
A18
A19
A20
A21
A23
A24
A26
A27
A29
A30
A32
A03
A04
A06
A08
A10
A16
A17
A18
A19
A20
A21
A23
A24
A26
A27
A29
A30
A32
Re: Ecu Pinout/ Function for p2t ECU "A" plug 32p (BLKCivicPorscheStyle*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKCivicPorscheStyle* »</TD></TR><TR><TD CLASS="quote">I put a 99-00 si motor and engine harness in a 96-98 civic that had a gsr harness and ecu in it. </TD></TR></TABLE>
Just a hint. Don't mix the 99-00 harness with a 96-98 car. And vice versa. Find a 96-98 harness.
Re: Ecu Pinout/ Function for p2t ECU "A" plug 32p (boomslang)
hey bloomslang..... i checked out ur site, and looks good i plan on purchasing one of your conversion harnesses, this is what i have, please tell me which one i need, thanx.....
01 b20z block
99 si head b16a2
99 si ecu
which harness do i need, a obd2a->obd2b or vice a versa???
thanx alot
01 b20z block
99 si head b16a2
99 si ecu
thanx alot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boomslang »</TD></TR><TR><TD CLASS="quote">
Just a hint. Don't mix the 99-00 harness with a 96-98 car. And vice versa. Find a 96-98 harness.</TD></TR></TABLE>
If you want the ECU pinouts, here
alacard
13
06-08-2007 06:10 PM
HondaPartsHero
13
11-24-2006 09:30 PM
