wiring conversion
Old Aug 11, 2005 | 10:56 AM
jadsi420's Avatar
Default wiring conversion
i recently purchased a jdm motor, b18c type r to swap into my 99 civic si. which wiring harness do i need to complete the job?
Old Aug 11, 2005 | 11:29 AM
db1b18c's Avatar
did your swap come with ECU and wiring harness? If it did then use that harness and ecu.
Old Aug 11, 2005 | 10:17 PM
locash's Avatar
Default Re: (db1b18c)
Don't even think of listening to this guy. You cannot use a JDM B18C engine harness in a US 96+ Civic. Use your 99 Civic Si engine harness, it should work pretty well if the JDM B18C engine is 96+ as well, and if you want to run an obd2a ecu, get an ecu adapter and be done with it.. If by chance the motor is of the obd1 variant, still use your 99 Si engine harness and make a few changes to it (injector plugs, distributor plugs, IAT sensor, etc)..
Old Aug 14, 2005 | 07:27 AM
jadsi420's Avatar
Default Re: (locash)
thanks. im on the look out for a harness.
sivik2nr
Jun 10, 2022 06:46 AM
93EssEYE
Jun 5, 2011 08:19 PM
TOFU.man
Apr 3, 2004 05:52 AM
blkrice
Oct 2, 2002 04:13 PM
