F23 with H22 head??
Old Aug 11, 2005 | 03:37 PM
H.Veras's Avatar
Default F23 with H22 head??
I have heard it but never seen it. Can it really be done? If so, what modification needs to be made? Thanks in advance
Old Aug 11, 2005 | 04:17 PM
slomofo's Avatar
GDD Member
Need to resleeve, I clayed it once on an F22, the H22 combustion area has a larger diameter than the F22 bore.
Old Aug 11, 2005 | 04:34 PM
skunked's Avatar
Default Re: (slomofo)
https://honda-tech.com/zerothread?id=1265175
Old Aug 12, 2005 | 07:19 PM
H.Veras's Avatar
Ok, it needs to be resleeve. That's what I thought. Thanks
Old Aug 13, 2005 | 07:24 AM
fastwanabe's Avatar
Default Re: (henslyrt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by henslyrt &raquo;</TD></TR><TR><TD CLASS="quote">Ok, it needs to be resleeve. That's what I thought. Thanks</TD></TR></TABLE>no it does not.
Old Aug 13, 2005 | 07:51 AM
H.Veras's Avatar
So, what does it needs to be done? Will it just bolt on?
Old Aug 13, 2005 | 10:47 AM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by henslyrt &raquo;</TD></TR><TR><TD CLASS="quote">So, what does it needs to be done? Will it just bolt on?</TD></TR></TABLE>nothing needs to be done to the block itself.... however the head needs little modification and so does the water pump and the crank timing gear need to be change, basically easy stuff. There is a thread in the Prelude forum that I used to get my motor running. I suggest you read all of it before you start. If you have a spare blow H22 block your basically set... all you would need is the F23 block.
Old Aug 14, 2005 | 07:28 AM
H.Veras's Avatar
I found that thread and it is worth reading it. It has the information I've been looking for a long time. If I had this inf before I would've already start that project. Looks like another G series is going to be built........Thank all of you guys, and thanks fastwanabe!!!
xmelanko
Jun 8, 2007 08:49 AM
deeweezy187
Oct 30, 2005 02:37 PM
DMF
Oct 10, 2005 09:54 AM
vybez
Oct 25, 2003 09:32 PM
zmr
Jun 18, 2003 12:44 PM
