Question about b17a???
Old Aug 26, 2005 | 06:33 AM
vtecn8ive's Avatar
Default Question about b17a???
Well I am hopefully purchasing a b17a soon. I am currently building a b16a2 sleeved to 84mm.
I was told that the b17a is pretty much a stroked b16. If this is true can I just drop it in my b16 or do the mains have to be changed to get it to fit correctly? Do the sleeves have to be notched at all?
What rods/pistons would I use? b17a or b16's??
-Shane
Old Aug 26, 2005 | 10:07 AM
vtecn8ive's Avatar
Default Re: Question about b17a??? (vtecn8ive)
Help me out. I've helped plenty of you guys out!!!!
Old Aug 29, 2005 | 05:48 AM
vtecn8ive's Avatar
bump
Old Aug 30, 2005 | 10:27 AM
vtecn8ive's Avatar
bump
Old Aug 30, 2005 | 10:39 AM
DocSean's Avatar
Bump, cause this is a darn good question.
Old Aug 30, 2005 | 11:28 AM
vtecn8ive's Avatar
Default Re: (spankjelly)
Okay so after searching for awhile this is what I came up with..
b16 block = b17 block
b16 crank don't = b17 crank
b16 pistons/rods don't = b17 piston/rods
What I am left wondering is if the b17 main caps are the same as the b16 ones.
Old Aug 30, 2005 | 12:01 PM
dategb16vortech's Avatar
Default Re: (vtecn8ive)
talk to Kevin (Pubestripe) or Hand command (Tony) they will give you specs
Old Aug 30, 2005 | 12:32 PM
vtecn8ive's Avatar
Default Re: (dategb16vortech)
You mean mean your mistresses Jon?
-Shane
Old Aug 30, 2005 | 01:36 PM
Suck it
Old Aug 30, 2005 | 06:04 PM
slomofo's Avatar
GDD Member
Rods/crank are different, rods are shorter, crank has slightly longer stroke, cams are also different. Everything else is the same except the intake manifold is stamped P61.
The valves are bigger than gsr valves, I don't know if all B16's are like that, I just know I bent my B17 valves and tried to throw gsr's in, but they were too small.
Old Aug 30, 2005 | 06:10 PM
Akiraboy's Avatar
Default re
oooo kkkk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">Well I am hopefully purchasing a b17a soon. I am currently building a b16a2 sleeved to 84mm.
-Shane
if you use b16a block sleeved to an 84mm bore you can't use b16 or b17 pistons
so, assuming(not to say you will,) you're using stock b series parts for this build then b20b or b20z pistons are in order since they are 84mm, these have different dome heights.
rods, depending on what rods you use, b16a rods are 134mm approx, b17a rods are 132mm.
crankshaft, b16a crank has a 77mm stroke, the b17a is 81.4mm aprrox.
Headgasket, you need to specify a thickness as this will affect your compression.
Head, I am assuming a b16a head too? Different b heads have different sized cc volumes
here just goto http://www.zealautowerks.com
choose the B series compression calculator
plug in your your different parts & see what ya get
just tried a certain combo, b16a block bored to 84 mm, b17 crank, b20z pistons, b16 rods, b16a head and a 2 layer headgasket. This combo yields an 11.36:1 compression ratio. Congratulations on that firebreathin 1.8liter, but usin your 84mm block, b18c crank, b16a head, b20b pistons, b17 rods and a 3 layer HG gives you 11.67 compression and 1933 ~ 1.9 liter displacement.
I had a link to the r/s ratio but I cannot find it right now, I'll look @ work tommorow...
The calculator is a guide, not gospel.
have fun
Old Aug 30, 2005 | 06:19 PM
vtecn8ive's Avatar
Default Re: re (Akiraboy)
well I was going to get some rods and pistons for turbo application. Thats why I was wondering what Pistons and rods I should use.
does it matter which mains I use for the main caps? Or can I get a z10 girdle?
-Shane
Old Aug 30, 2005 | 08:25 PM
Akiraboy's Avatar
Default Re: re (vtecn8ive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">well I was going to get some rods and pistons for turbo application. Thats why I was wondering what Pistons and rods I should use. </TD></TR></TABLE>
ok, then use the compression calc & plug in the numbers...
-Shane
this may be someone elses line of expertise sorry
I would like to say that you may need to contact z10 for that answer
Old Aug 31, 2005 | 05:29 AM
vtecn8ive's Avatar
Going contact them shortly to find out the answer
ThatOneOG
24
Jun 24, 2009 07:27 AM
chuisek9
Apr 15, 2008 06:37 AM
EgGriff
Mar 12, 2005 08:41 AM
mrbsponge
Jan 10, 2005 04:10 PM
Fleas_Ef
Aug 4, 2004 03:55 AM
