vtech cylinoid kicking on an off
vtech cylinoid kicking on and off at 5000 rpm, it wont rev past 5000 rpm in second gear half the time, help!
Re: vtech cylinoid kicking on an off (WHTGEN2)
are you throwing any codes? the cause of not revving past 5k could also be a ignition or fuel problem.. Also you should try to check all your vacuum hoses.
Re: vtech cylinoid kicking on an off (JDMtype Eg6)
I havnt checked the computer yet, i have not had the chance to hook up the o2 sensor or i think its the oil pressure switch, im using obd0 computer, do i have to get a computer from a vtec car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WHTGEN2 »</TD></TR><TR><TD CLASS="quote">I havnt checked the computer yet, i have not had the chance to hook up the o2 sensor or i think its the oil pressure switch, im using obd0 computer, do i have to get a computer from a vtec car?</TD></TR></TABLE>
First off, you shouldn't drive your car again until you hook up an o2 sensor. Next, you need a vtec ecu for vtec to work, may i suggest the correct ecu for whatever engine you have, as the fuel and ignition maps are pretty damn important too. I have a feeling it'll be a while before you get it running right...
Re: vtech cylinoid kicking on an off (eg6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T »</TD></TR><TR><TD CLASS="quote">buy a new phone battery</TD></TR></TABLE>
Thats Great!
Thats Great!
