transmission/motor mounts
Old 08-11-2005, 12:30 AM
jadsi420's Avatar
Default transmission/motor mounts
im currently swapping a b18c type r engine into a 99civic si. Ive been reading the posts as to the required mounts and was wondering if i had the right idea. From what i understand all but the driver side mount are to be from the integra r and i should use the stock mount for the driver side. Anything will help. thanks.
Old 08-11-2005, 07:16 AM
YZFR6's Avatar
Default Re: transmission/motor mounts (jadxi420)
You could you use your stock engine mounts if you'd like. Just need to change the timimg belt cover mount to a 99-00 Civic Si. Also we have a 5 peice complete upgrade mount kit for your car that replaces the factory gel driver side mount. Hope this helps.
es_squared
01-27-2009 07:22 PM
Nova_Dust
03-14-2008 04:40 PM
dwerpk
12-25-2006 11:22 PM
mhx
06-08-2006 10:09 AM
DJ_SaNdOz
02-10-2003 09:10 AM
Quick Reply: transmission/motor mounts
