ECU problems
Old Aug 21, 2005 | 02:30 PM
Supa_Slow_Civic's Avatar
Default ECU problems
Alright guys. I just did a b20 vtec swap in to my 99 ek...an im having some problems with the ecu's. Here the deal i have a jdm p30 with a bad jumper harness so its throw a check engine lite for vtec pressure, so what i did was put in the stock ecu and it ran fine, but its throwing a check engine to for the crank senor or something like that.....So Last time i drove my car around for bout an hour with the stock ecu ran fine, then when i went leave my friend house it started blogging down...it would idle fine but when i went to go take off it had to rev it super high to get the car to move....so i figure it wasnt getting enough fuel....so i pulled over swap out the ecus it ran like **** for a min then i slowed down and launched my car it seem to be fine no blogging no nothing. an then this morning i went to go check it out with the p30 hooked up it was blogging like the single cam ecu did. so i cam home plug up the single cam ecu and it idle fine didnt have any kind of blogging what so ever....Any ideas on what might be causing these problems?
Old Aug 21, 2005 | 06:48 PM
v4lu3s's Avatar
RTFM
i would get an ecu tuned to match that engine, neither of those ecus will work too well for what yoau re doing.
Turboshooter44
Apr 17, 2015 09:22 PM
blackhbkid
Jan 16, 2006 12:07 AM
Supa_Slow_Civic
Aug 22, 2005 05:24 PM
impact_blu
Aug 18, 2005 01:36 PM
crxtreme27
Jul 1, 2003 04:30 PM
