91 DA-LS to a JDM B16A-need help w/ wiring and vacuum
Swapping out an LS in a 1991 Teg LS,with a JDM B16A motor.Having trouble finding a pinout guide for the vtec wiring into the ecu.Im using the stock B18A1 wiring harness and just running the extra wires to the ECU.If anyone could give me a hand finding the diagram or something similar to an ECU pinout for the B16A ECU to finish the wiring.
Also having a little trouble with the few little vacuum lines in the manifold/and the map sensor etc.should i try to just use the diagram under the hood or is there a different way to hook up since the manifold is different?
trying to finish this thing and get it running hopefully this weekend,need it to get back and forth to work.ill post up some pics of the swap later tonight.thanks in advance for any help.
Re: 91 DA-LS to a JDM B16A-need help w/ wiring and vacuum (jsnm)
http://www.hondaswap.com/forum...7217 THIS IS A LINK TO A WEBSITE THAT HAS A VTEC WIRING DIAGRAM
