another quick bracket question
Old Aug 17, 2005 | 08:55 PM
jadsi420's Avatar
Default another quick bracket question
swapping a 2000 jdm b18c r into a 99 civic si. Because this engine is jdm do i need a different driver side mounting bracket. I only ask because the spacing on the rubber mounts on the block seem closer together than the si bracket.
Old Aug 18, 2005 | 12:40 AM
WickedSol's Avatar
Default Re: another quick bracket question (jadxi420)
To answer your question, No..You would use the b18c driverside stabilizer bracket and change the rubber mount to the 99 civic si rubber mount. 19mm... Good luck with your swap!
Daniel99
Jul 12, 2018 09:17 PM
brizjuan
Jul 20, 2004 03:22 PM
J.R.
10
Jan 12, 2004 08:27 PM
speedaholic92
Apr 11, 2003 08:55 PM
CanuckCRX
Jan 2, 2003 08:06 PM
