Swapping from b16a to d16z6
Ok well I am going to be swapping from a b16a in my EH hatch... to a d16z6 that is coming from a del Sol. Me and the guy are doing a direct swap at a garage. Now... what will I need to successfully do this swap besides what he already has? I mean... he has mounts, axles, ECU, etc... will everything drop right in and fit? Thanks!
Re: Swapping from b16a to d16z6 (Mario.)
THE Z6 TO THE HATCH SHOULD BE SIMPLE JUST SWAP THE ENGINE HARNESS AND ECU OUT OF THE DEL SOL. HELL REALLY THEY SHOULD BOTH GO PRETTY SMOOTH JUST SWAP HIS ENGINE HARNESS AND ECU TO UR CAR AND UR ECU HARNESS AND ENGINE INTO HIS CAR
Re: Swapping from b16a to d16z6 (97dxSi motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dxSi motor »</TD></TR><TR><TD CLASS="quote">THE Z6 TO THE HATCH SHOULD BE SIMPLE JUST SWAP THE ENGINE HARNESS AND ECU OUT OF THE DEL SOL. HELL REALLY THEY SHOULD BOTH GO PRETTY SMOOTH JUST SWAP HIS ENGINE HARNESS AND ECU TO UR CAR AND UR ECU HARNESS AND ENGINE INTO HIS CAR </TD></TR></TABLE>
Why do I need to swap the harness if they are both OBD-1???
yeah everything should just swap right over with out having to change the harness, the only thing is (which im not completly sure about) the b16 harness may have a plug for a knock sensor but if you dont change the harness just leave it unplugged on the new motor, with the del sol computer it wont throw a code
Re: Swapping from b16a to d16z6 (UpgradesLLC)
Ok right on. Now how about shift linkage? The del Sol guy said he needs to get new linkage. Do I???
Moderator
Re: (BlazedD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlazedD »</TD></TR><TR><TD CLASS="quote">why from a b to a d...</TD></TR></TABLE>
why not
maybe he needs money!!
why not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UpgradesLLC »</TD></TR><TR><TD CLASS="quote">yeah you need sohc linkage and axles</TD></TR></TABLE>
Is that ok if they are from a del Sol???
Yep... shifting priorities. Don't need a haul-*** car anymore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario. »</TD></TR><TR><TD CLASS="quote">Is that ok if they are from a del Sol???
Yep... shifting priorities. Don't need a haul-*** car anymore. </TD></TR></TABLE>
Re: Swapping from b16a to d16z6 (chad)
Yup, Del Sol shift linkage will not work. You need to find any old D series shift linkage from any civic 92-00 (non B series).
Re: Swapping from b16a to d16z6 (ih8jdm)
Thank you much fellas! So the only thing that won't work is the linkage? The mounts will swap over ok?
Question: I have an Evasive Dual Bend Short Shifter right now that I really really like. Will I be able to use this with the d-series or do I need to get a new one?
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario. »</TD></TR><TR><TD CLASS="quote">Question: I have an Evasive Dual Bend Short Shifter right now that I really really like. Will I be able to use this with the d-series or do I need to get a new one? </TD></TR></TABLE>
you will hvae to make it work
it can be done
have done it many times....
just use washers if it fits to loosely in the lower shifter bar
it can be done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">you will hvae to make it work
it can be done
just use washers if it fits to loosely in the lower shifter bar</TD></TR></TABLE>
Ok thanks man.
The rear tranny bracket... do I need the whole mount or just the bracket? It's just the metal piece right?
it can be done
Ok thanks man.
