GSR in a CRX what rear mount?
So i have a gsr that i'm putting in my crx. Have a cable tranny already and hasport b series into EF with cable tranny 3 motor mount kit.
But I dont' know what rear tranny bracket I need. I remember pulling this motor out of EK hatch, and putting a b16 in there and one of the brackets I had was like a half inch off and couldn't bolt up to the EK rear mount. I'm thinking the other bracket I have will work, but wanted to cross check mount part numbers to make sure before I start swapping in this gsr motor.
Thanks.
P.S. Yes I searched, couldn't find anything.
Thanks.
Re: GSR in a CRX what rear mount? (rice is nice)
If you have a cable trans you'll need a rear "T" bracket from a 90-93 integra 5spd. If you have a '94+ hydro trans you'll need the same bracket but you'll need to drill out the two lower holes to accept the bigger bolts.
Re: GSR in a CRX what rear mount? (88ED8)
yeah I got a cable trans, any idea if the T bracket has a part number stamped on it? If so, what is the part number? I'd look on majestichonda, but that's just honda, not acura. Thanks.
ESP.net
12-30-2013 11:35 AM
CapnKrunch
09-01-2010 07:19 AM
allmotor1313
03-10-2008 08:13 PM
