ls integra swap
Old Mar 24, 2008 | 12:41 PM
orange94teg's Avatar
Default ls integra swap
i have a 94 ls integra and it needs a new motor and i was thinking of going with a gsr swap or a b16 swap and i no to do the swap i need the motor ecu and engine harness for either of the motors but my question is will these engine harnesses hook up to the harness already in my integra and if any futher wiring would need to be done for vtec
all input welcome thanks in advance
ryan
Old Mar 24, 2008 | 03:41 PM
helpmeplease's Avatar
Default Re: ls integra swap (orange94teg)
i think you are going to need a wire for the vtec if you stay with the ls harness.
Old Mar 24, 2008 | 07:47 PM
Tarmac Junkie's Avatar
Also knock sensor. And if you go with a gsr you will also need to wire the iab on the intake manifold.
Old Mar 24, 2008 | 08:20 PM
Default Re: ls integra swap (Tarmac Junkie)
how hard is it to wire the car for vtec and with the iab and knock sensor is that the same with all vtec motors or just the gsr
Old Mar 24, 2008 | 08:48 PM
To wire vtec and knock is just some wire to the correct ecu pin. The iab is specific to the gsr, some people don't wire it but I do. Its so the manifold will change from the long to short runners in the intake manifold, when the rpm's increase. Only the gsr has this. Its 1 wire...
Old Mar 24, 2008 | 09:06 PM
ok thank you
Old Mar 25, 2008 | 08:52 AM
jdmassejcoupe's Avatar
best off just having someone make you a harness for like a 100 bucks make things much easier
GSR936
Feb 18, 2010 05:55 AM
WiCkEdInTeGrA666
Feb 13, 2009 04:54 AM
FullJDMEg
May 4, 2006 11:13 PM
myDC4rox
Jan 9, 2005 06:54 AM
BeanRacer
Dec 11, 2001 08:47 PM
