NEED HELP BAD!!!!
Old Apr 1, 2008 | 06:51 AM
supaslowdx's Avatar
Default NEED HELP BAD!!!!
Ok just swapped a B16A into a 98 dx coupe. Everything seems to work fine but runs like in limp mode I think. wont rev past like 3400 or so. Seems to run smooth and idle great though. Any help would be greatly appreciated. Anyone that knows what could cause this please help. BTW I used wiring diagrams to convert the dizzy, injectors, iacv, and still no fix.
Old Apr 1, 2008 | 02:35 PM
chad's Avatar
Moderator
Default Re: NEED HELP BAD!!!! (supaslowdx)
if it is in limp mode then there is a code...we need to know that code!
Old Apr 2, 2008 | 04:50 PM
supaslowdx's Avatar
Okay...it shows code 4 which is CKP sensor...the wiring is correct I even switched them to see...what else could be causing this???
I put this dizzy on a running car and it worked fine
I have no idea what else it could be???
Old Apr 2, 2008 | 07:51 PM
daveedd357's Avatar
you probably have the wires reversed, signal to ground, ground to signal.
Old Apr 2, 2008 | 08:03 PM
supaslowdx's Avatar
Default Re: NEED HELP BAD!!!! (daveedd357)
I switched them and nothing happened???
Old Apr 3, 2008 | 06:50 PM
supaslowdx's Avatar
Anybody got any ideas?
Old Apr 4, 2008 | 02:22 PM
supaslowdx's Avatar
Desperation is setting in...please help
Old Apr 5, 2008 | 03:40 PM
supaslowdx's Avatar
FIXED.
Shut it down...
SinglecamMitch
Dec 15, 2008 05:57 PM
Bright Eyes
Jun 3, 2005 05:52 PM
Schaz
May 18, 2005 10:53 PM
Red_Si
21
Jan 9, 2004 04:53 AM
2000CX
Aug 4, 2003 12:32 PM
