Ls/Vtec GSR head problem :(
Old Apr 22, 2008 | 05:59 PM
shiftjdm's Avatar
Default Ls/Vtec GSR head problem :(
I tryed searching but I couldnt come up with to much. I have this problem for when I start it up its really bogging down for the first 1-2 minutes, then idles ok. It has this almost loud knock, in the head by the #2 piston. The compression test was good, the timing is perfect, I just got done changing basically the ignition system, right along with alot of other things. It sounds like the knock is coming from the intake side. It also happens every time you rev it up then let it go back to idle, the sound is extremly loud, we looked at the head with the cover off, it looked fine. We've done all that we know of to find out what the problem is, without tearing the head done yet.
Any help???
Old Apr 22, 2008 | 09:30 PM
oompalumpa61's Avatar
Default Re: Ls/Vtec GSR head problem :( (shiftjdm)
Have you checked to see if your valve lashes are in spec?
pipojdm
Sep 26, 2011 06:05 PM
shiftjdm
Apr 29, 2008 06:43 PM
T3k C
Mar 19, 2007 02:22 PM
I got a honda
Aug 28, 2005 06:42 PM
98-ls
Apr 16, 2004 11:11 PM
