trans issue. spewing fluid WTF?
Old Apr 8, 2008 | 06:27 PM
slambedcivic's Avatar
Default trans issue. spewing fluid WTF?
today i put my swap back in after pulling the engine apart and checking things over. got it somewhat running and wanted to take it for a ride to see how it ran. i didnt get on it (like not even passed 1/4 throttle). i heard a pop and something scraping. i shut down immediatly. got as far under the car as i could and didnt see ****. i start it up (no noise) and creep home. i park it, head inside to do some domestic dutys. come back out and theres a puddle under the car. i immediatly freak out, jack the car up and climb under. fluid is pouring out of the bellhousing. this transmission worked FINE when pulled from the car. I cant afford another ITR trans. and ideas what this might be since i wont be able to get to it until thursday.
TIA
Old Apr 8, 2008 | 07:32 PM
sirtef9's Avatar
Default Re: trans issue. spewing fluid WTF? (slambedcivic)
Whatd you pull apart on your motor? Sounds like the main seal shitted out on you.
Old Apr 8, 2008 | 08:43 PM
Default Re: trans issue. spewing fluid WTF? (sirtef9)
i pulled the engine engine apart and clearanced everything. i put new cams in and clayed it. NOTHING to do with the trans. popping the seal out doesnt explain the grinding. im so scared that theres a hole in the case.
Old Apr 9, 2008 | 06:21 AM
just thought about something else. would a rock break the casing? i dont have a dust shield on my trans. this is the first car ive ever run without one. but my moroso oil pan and smsp header will not allow the dust shield to be mounted.
Spud1237
Transmission & Drivetrain
Jun 25, 2019 06:09 AM
Probot
Jan 4, 2008 04:22 AM
Probot
Jan 2, 2008 06:26 AM
PsychoSiRex
15
Mar 25, 2004 12:59 PM
shinra
Dec 25, 2002 08:59 PM
