Is a/c even possible on H2B??
Old Apr 2, 2008 | 06:49 PM
turboedsupe's Avatar
Default Is a/c even possible on H2B??
So after all the research it looks like hondas have run a belt for the a/c and ps and then one for the alternator. If doing a h2b makes you run a 3-rib single belt pulley how would it even be possible to have the compressor hooked up? I am new to hondas but am wanting to do this swap badly i just dont think i can live without a/c in phoenix. Any help will be appreciated and yes i already searched with no answers
Old Apr 2, 2008 | 06:50 PM
Default Re: Is a/c even possible on H2B?? (turboedsupe)
And its goin in a eg hatchback
Old Apr 2, 2008 | 06:51 PM
2fast4u831's Avatar
I'm really 2slow
possible
Old Apr 2, 2008 | 07:11 PM
Default Re: Is a/c even possible on H2B?? (2fast4u831)
Thats good news Now how would one goin about doing it? I am also on a tight budget so thats not going to help out
Old Apr 3, 2008 | 11:34 AM
xv53's Avatar
Easiest way it could work is using the HCP h22 to d-series a/c compressor bracket. Only thing is that it is discontinued and it rarely pops up for sale.
I was in the process of doing this but I sold my h2b setup so it was never completed. This was for an H2B in and integra. This is what I did:
get the explicit speed h22 d-series upper alternator bracket.
get a p13 a/c bracket and a p72 a/c bracket and a/c compressor
mount the d-series alt bracket and alternator
mount the p13 a/c bracket to the motor
mount the b-series a/c compressor to the p72 alternator bracket
mock up the p72 alternator bracket up against p13 alternator bracket.
line up the alt pulley, crank pulley and a/c pulley.
tack weld the p72 alt bracket to the p13 alternator bracket.
this is where i stopped. I needed a fabricator to make 1 a/c bracket from the combined p13 and p72 brackets that was welded together. Then I sold the setup so it was never finished.
It might have been a tight fit for the compressor lines with the explict speed alternator bracket where it was located. The alt bracket would probably have to be modifed to make it mount a little higher to free up some room. I wish I could have finished it and got it working.
Old Apr 3, 2008 | 04:29 PM
Default Re: Is a/c even possible on H2B?? (xv53)
Thanks for helping guys!! So it would work off running the same belt for the alternator and crank? I was just worried it wouldnt charge the battery enough or have enough to run the compressor on just one belt. I have someone who will customize the bracket i was just making sure i could run 1 belt for everything. Also wanted to make sure if i did run 1 belt that it would clear every thing.
Old Apr 4, 2008 | 05:15 AM
csulliva's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboedsupe &raquo;</TD></TR><TR><TD CLASS="quote">I am also on a tight budget so thats not going to help out</TD></TR></TABLE>
That's always a good place to be when you're doing custom fabrication. lol.
I'm sure it COULD work.
I requested some pictures a while back of the area so maybe I could start to fab up a bracket, but I got no help. I'm a Mech Eng. with access to a full CNC machine shop, but no one posted any pictures of their setup.
I'm not even going to think about doing an H2B if there's no AC. 95 with 100% humidity here in the summer, and I'm headed to work in a suit? F that, F that right in the A.
Old Apr 4, 2008 | 04:04 PM
Default Re: Is a/c even possible on H2B?? (csulliva)
I work for baer brakes and a engineer said he would make the bracket for me so its going to get done. the only thing is moving it over a 1/2" to line up with everything since im using the alternator relocation bracket that moves it over.
I have found these pics of the a/c bracket
http://www.jdmshit.com/hcp/EGf...e.jpg
https://honda-tech.com/zerothread?id=762329
6th pic down for the eg one
Old Apr 6, 2008 | 09:34 AM
RotiEatter's Avatar
Ditto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by csulliva &raquo;</TD></TR><TR><TD CLASS="quote">
I'm not even going to think about doing an H2B if there's no AC. 95 with 100% humidity here in the summer, and I'm headed to work in a suit? F that, F that right in the A. </TD></TR></TABLE>
blah blah blah
I used to drive to work in a gutted flat black hatch in a shirt and tie everyday and I never thought it was that big of a deal.
And I live in Atlanta, so 95 with 100% is daily summer conditions.
Old Apr 6, 2008 | 02:14 PM
Default Re: Is a/c even possible on H2B?? (RotiEatter)
Well i dont want to be one of those guys walking around with a big old sweat ring on there back Here in phoenix it will drive you made at red lights sittin with no a/c. Well thanks for the help guys ill be back with some pics of the setup in like 4 months
v1sion
Apr 5, 2011 01:43 PM
Silvertc
Jun 18, 2008 02:02 PM
Silvertc
Jun 15, 2008 06:12 AM
Silvertc
Jun 6, 2008 07:54 PM
.BigSexy
Jun 6, 2006 12:06 PM
