f2b
Old Apr 22, 2008 | 06:33 PM
EG6 Love's Avatar
Default f2b
im sorry if this has been asked but i looked real quick and i didnt see anything.
ive always been all b-series and im jus now lookin at these h2b and f2b swaps. still learning alot but...
i figure when f2b is talked about, the accord engine is wats assumed but since ur using a b series tranny can u use an f20c outa the s2000 and still use it as a front wheel drive in a civic?
Old Apr 22, 2008 | 08:36 PM
toyomatt84's Avatar
Sanji
Default Re: f2b (EG6 Love)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 Love &raquo;</TD></TR><TR><TD CLASS="quote">i figure when f2b is talked about, the accord engine is wats assumed but since ur using a b series tranny can u use an f20c outa the s2000 and still use it as a front wheel drive in a civic?</TD></TR></TABLE>
Nope, but you could use a K-series transmission. And, before you ask, yes it has been done before a couple times.
Old Apr 23, 2008 | 03:33 AM
EG6 Love's Avatar
Default Re: f2b (toyomatt84)
any k series tranny in particular?
Old Apr 23, 2008 | 06:18 PM
EG6 Love's Avatar
bump
Old Apr 23, 2008 | 07:34 PM
sportybanana's Avatar
Default Re: (EG6 Love)
I believe all the housings are the same so if you know someone that is good at wiring they would probably be able to make any of them work... although im not sure y you would even want an s2k engine as they are pretty maxed out from the factory and for what you'd be spending you could just do a k20 and avoid the headaches of doing a little known swap.
Old Apr 23, 2008 | 08:41 PM
toyomatt84's Avatar
Sanji
Default Re: (sportybanana)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sportybanana &raquo;</TD></TR><TR><TD CLASS="quote">I believe all the housings are the same so if you know someone that is good at wiring they would probably be able to make any of them work... although im not sure y you would even want an s2k engine as they are pretty maxed out from the factory and for what you'd be spending you could just do a k20 and avoid the headaches of doing a little known swap.</TD></TR></TABLE>
K24 housings are different than K20 housings.
Old Apr 24, 2008 | 06:27 PM
EG6 Love's Avatar
im jus testin some waters for a swap so ur not the first to say jus go wit a k20. ill prolly take ur advice
Old Apr 28, 2008 | 11:31 PM
Default Re: (toyomatt84)
i know the thread is rather old but i was referring to the five speed k20 and the six speed k20 trannies as my friend just swaped the internals from one to the other.
Old Apr 29, 2008 | 04:44 PM
gibsanez's Avatar
I don't see the point in an F2K swap.
Old Apr 30, 2008 | 03:35 AM
EG6 Love's Avatar
Default Re: (gibsanez)
now that ive read alot more and asked alota questions... ur right. there is no point. k20 swap is better cause an f20c is pretty much already maxed out and if u want anything else other than JUST an f2k swap than its better to go k20
Old Jul 27, 2009 | 12:27 PM
Cidone's Avatar
Default Re: f2b
Hey im doing a F2K swap to be diff. i wont make as much power as a K but ive already had 3 diff K swap cars and they are being done alot more now. Im starting a business so it will bring people to our booth at shows.
Old Jul 29, 2009 | 12:38 AM
raidacaipo's Avatar
Default Re: f2b
f20c block mated to a K series tranny eh? are there any more threads like this?
Old Aug 1, 2009 | 04:52 AM
Cidone's Avatar
Default Re: f2b
Inline Pro made the kit but i dont think they started a thread. Guy in Jersey did a swap and has a small thread on it but other then that i think im the only other one.
Old Jul 26, 2010 | 07:24 PM
Hondenver's Avatar
Default Re: f2b
so how are you guys claiming that the S2K motor is "maxed out" If that were the case then there wouldn't be guys making any where between 500 and 1000HP (which they are) there are tons of aftermarket mods to increase the power of this motor.
And It has also been stated that the F2K swap wont make as much power as a K swap hm..... well the K20a Type r motor makes 220hp and redlines at 8600rpms and the F20c has 250hp and revs to 9000rpms
so tell me how that is less power
I dont mean to take up space on the OP's thread but it just doesnt set right with me....
I would love to do a F2k swap because it is out of the "norm" everyone has B series and everyone wants to do K swaps and now the cool new trend is the H2B swap
If you wanna do the F2K swap then go for it bro i think its a pretty bad *** swap
all these people that gotta hate on a motor swap because it isn't a K swap make me wanna rock a Dseries for the rest of my life
anyways thats my .02
I'm down with the F2K
adubaz7
Welding / Fabrication
51
Oct 12, 2007 07:38 AM
russianswty
Feb 4, 2007 01:29 AM
vtec fan
May 15, 2006 02:09 PM
fearsom
Honda S2000
13
Aug 15, 2005 12:35 AM
sockvtec
Honda S2000
17
Dec 15, 2004 06:24 PM
