B16A swap 99% complete, Honda GURU HELP needed!
Car: 1999 Civic DX / OBD2B
Swap: 1992 B16A with type-r head internals
Harness: Stock OBD2B harness with Skunk2 harness conversion
ECU: P28 chipped
Distributor: OBD1 (two connector harness)
My question is about the Dizzy, how do I convert the two connectors on the OBD1 distributor so that it will work with the stock OBD2B harness that only has one connector on it.
Found what I needed and the swap is now 100% complete!
-Green/Black wire to Yellow/Black wire
-Bleu wire needs to be extended from on top of the driver side shock tower, its a single wire connector, thats your RPM signal!
Modified by accordv66speed at 12:14 PM 4/25/2008
ECU: P28 chipped
Moderator
Re: B16A swap 99% complete, Honda GURU HELP needed! (accordv66speed)
msd makes a jumper harness if you wish to keep that area "CLEAN" I believe it is 28 bucksish.
chad
chad
vidanator
01-24-2005 01:27 AM
Civicboy
09-18-2002 09:37 PM
