my car cranks but not starting
ok i have a 94 integra ls shell but a jdm type r motor when i bought it and was swaped already. it was fine for about 3 months. it stated to bog around 3000 to 3500 rpm. then i parked it for 3hr and went back to start it but i won't star it would just crank. i'vd checked the distriputor check the fuses, battary and grounds and when i turn the car on i can hear the fuel pump working. the car smell just a little gas form some where under the hood. it also has check engine light on code6 code10 code20 and the timing belt is kind of loose but when the car cranks the cams rolls. had any one had this problem or might know how to fix this promblem please help me out.
Re: my car cranks but not starting (loc_yaj)
what did you check in the dizzy? is there spark? youve got fuel, and youve got air, now you need fire....
