EFH1 Problems
Old Apr 13, 2008 | 04:24 PM
Tompen's Avatar
Default EFH1 Problems
Hey,
Im having issues with putting an H22a into a CRX using the Hasport mounts.
I can get the 2 side mounts to line up but then the rear mount wont line up. Or i can get the rear and gearbox mount lined up but not the timing belt side.
Its a 2000 Euro R motor and gearbox, using the EFH1 kit and the rear bracket from Hasport.
As you can see the mount is way off.
Also I have no idea how the hydro to cable adaptor works, maybe its because over here in NZ we are RHD and our clutch cable comes a different way. Ive emailed Hasport but havent recieved a helpful reply.
Basically the bottom arm is fixed and the top arm is free to move. To me it makes sense that the bottom arm free to move and the top arm fixed. Does the USDM clutch cable run under the gearbox?
Canadian_EF
Apr 7, 2013 02:39 PM
just getting started
Jun 20, 2008 12:47 PM
blaak-crx
Apr 23, 2008 09:02 PM
ricodemus
Apr 13, 2002 07:03 PM
