D14A4 Head problem
Old Feb 19, 2009 | 05:17 AM
Hegster's Avatar
Default D14A4 Head problem
I need new head for my D14A4. Is it possible to use any other head without ECU programming? I got good offer for D15B7 head, can i use that?
Old Feb 19, 2009 | 05:38 AM
V8 Eater's Avatar
Default Re: D14A4 Head problem
I would check with these guys first!
http://www.d-series.org/forums/showthread.php?t=72784
http://www.dodo-upgrades.nl/
Old Feb 19, 2009 | 04:28 PM
slomofo's Avatar
GDD Member
D15B7 head should work fine, but the third hole on the power steering bracket may not bolt directly to the head, so you might have to leave that hole without a bolt. The other two bolts on the power steering bracket should be sufficient enough to hold your pump though (I've done it numerous times using D15B7 head on D16A6 blocks, it's the same scenario).
Old Feb 20, 2009 | 10:42 AM
Hegster's Avatar
Im going to dump power steering anyway so that doesnt matter.
But are combustion chambers same on D14 and D15 heads? Im considered about air-fuel ratio.
Old Feb 20, 2009 | 09:22 PM
slomofo's Avatar
GDD Member
The heads are the same, even the sleeves and pistons are the same as well. The difference between the two engines is the crankshaft and connecting rods, but everything else is the same motorwise (intake/exhaust manifolds are also completely different, but that doesn't matter)
Old Mar 2, 2009 | 08:48 AM
Hegster's Avatar
Thanks. What about D15B2 head? BTW do you know combustion chamber volume for D14A4 head?
sanman000719
Jan 22, 2011 04:59 PM
natzimus
Apr 27, 2006 06:04 AM
gt35r
Northwest (Sales)
Oct 6, 2005 09:28 PM
QCKGSR
Apr 14, 2003 06:49 PM
