hmotors ZC swap into 97 dx?
he said the jdm zc for 96-97 will work. and run on my current ecu [obd2a non vtec]
what all will i need?
and what is the motor hes talking about
I need more info because im swapping it myself
Seagull Management
Re: hmotors ZC swap into 97 dx?
JDM SOHC non vtec ZC i assume. Its basically a D16Y7 with a Y8 intake manifold and exhaust manifold. basically reuse your old intake and exhuast and perform the CKF trick shown here ---> http://technet.ff-squad.com/ckftrick.htm and thats about it.
Seagull Management
If the ZC came out of an automatic and used a 3 wire throttle body IACV then yes you can use it. If it came with a 2 wire IACV on the back of the IM block off these ports and reuse the Y7 throttle body.
prelude182
01-07-2010 12:34 PM
Mr.Death
06-22-2006 12:18 PM
VelocityR
11-14-2003 07:22 AM
