dumb ek swap questions
sorry i know these are stupid questions and i should know the answers i just wanna double check before i throw this motor in the car
putting a b16 into a 97 civic coupe
will dc axles and shift linkage work?
will the rear motor mount bracket off a b16a from an ef or a dc rear bracket?
will single cam injectors work?
will the single cam drivers side motor mount bracket that bolts to motor work?
Re: dumb ek swap questions
will dc axles and shift linkage work? yes
will the rear motor mount bracket off a b16a from an ef or a dc rear bracket? you need 99-00 civic si bracket
will single cam injectors work? yes
will the single cam drivers side motor mount bracket that bolts to motor work? you will need 99-00 si mount bracket (the one that bolts up to the block) all other mounts will be stock
Sinlge cam injectors wil work but they do not have the same flow rate and DOHC vtec injectors. 190cc vs 240cc I think. Not totally sure about the numbers.
sanegb16
09-05-2007 01:41 PM
deviant1
03-21-2003 11:03 PM
