Cluth works off and on grinding!!!!!
i was driving my del slow (b18c)the other day clutch workin alright slightly hard to get into fifth all other gears fine. Parked the car then 20 min later go to leave and the car wouldnt go into any gear. Then after a while of fighting wit it she wit into third,while moving she went into gear ok slighty hard tho .Well changed out the clutch master cylinder (used),the slave cylinder (new),still would grind when trying to put in gear and rpms would start to drop.Left it alone for 2 hours for ***** and giggles i tryed again work perfectly fine.whats wrong and in the mornings she would move forward while not in gear only cold and pushing in the cluth the rpms would raise a few 100 and was like that for a while
Re: Cluth works off and on grinding!!!!!
sound like your clutch isnt disengaging. prolly something in your hydraulic system. low fluid can cause that problem.
fluid not low could it be something clogging the line i ran 2 12oz bottles through it could it be my syncros or my throw out bearing will they give problems like wut i got and today she goes into 1st good but 2nd grindes but goes in gear 3rd grindes and pops out like cant even go into 3rd 4th and 5th good 1st 2nd 4th and 5th feel a little notchy tho
Sounds like the springs on your clutch are falling out. You might want to pull the trans off and inspect the clutch disc. Happened to a friend just a few months ago.
