Having some axle issues H22 EG
Swaped H22 into EG Hatch and having axle bind on the drivers side. Running old style avid racing mounts and started with ebay axles. Then tried a 88-89 integra with prelude inner. Still binds up. They are both the same length and there is no play in the length with the axle nut off. Car is at stock height. I am running a LSD(m2b4) tranny if that makes any diff, but don't think it does. Any Ideas? Was trying to avoid DSS and wanted to run something I could pick up locally.
Re: Having some axle issues H22 EG
It used to be that you could use a DA axle with a prelude inner with the old hasport motor mounts. Then Hasport changed the positioning of the motor and that required custom axles. Avid basically copied Hasport mounts or their positioning so they probably require the same axles as the newer hasport setup.
I think you might be out of luck if you are trying to use something off the shelf. are you breaking the outers? That is what happened to my buddy when he was running DA axles on his EK. Kept exploding the outer CV.
He got the hasport axles and was set from there...
ScottEK
08-23-2006 04:58 AM
