OBD1 motor in a 2001 Integra Type-R
Hey guys, Im swapping a fully built (240whp) OBD1 motor into a 2001 Integra Type-R and I have a couple questions about wiring. I did do some searching and found out alot but I do have some specific questions.
- I read that the connectors on the shock tower from the 96-01 Integra will accept the OBD1 Engine harness and since my car is a VTEC car, there is no extra wiring to be done. Is it as simple as that or did I misunderstand?
- I also read that I can use an OBD2b to OBD1 jumper harness on the ECU and run an OBD1 ECU? Is this correct?
- So the 2001 Integra (OBD2b) harness from the shock tower to inside the car can be re-used?
It seems to be really simple or am I missing something here?
Re: OBD1 motor in a 2001 Integra Type-R
You are missing Nothing ...all 94-2001 Integra Harnesses Work ...On All 94-01 Integra's
And yes you just use a OBD2B - OBD1 Jumper Harness and ur all Set...!
