no spark
Old Feb 21, 2009 | 04:57 PM
baysic r's Avatar
Default no spark
i think this should be here. i used an obd1 gsr block in a obd2 type r while i'm building the type r block but when i went to go start it there is no spark so i was thinking that the crank angle sensor might have something to do with there being no spark but i'm running a p28.
so would the crank angle sensor matter at this point or should i look at a different area?
it was strange cause it sounded like it wanted to start but i pulled the valve cover off to make sure i was getting oil in the head so i pulled the valve cover off. i was getting oil put the valve cover back on went to start it and then no spark.
any help or info would be helpful cause i don't know what else to do.
thanks in advance
Old Feb 22, 2009 | 09:12 AM
WhiteSol's Avatar
Default Re: no spark
Are you using your stock ITR harness? Grounds hooked up? What distributor?
kevozoomslbc
Apr 19, 2014 10:37 PM
Chrisdc2
Jun 27, 2011 04:24 PM
civicdreamteam
Apr 24, 2010 10:59 AM
lke2drvgsr
Sep 29, 2003 07:25 PM
